Hello, I have a Kitchen Aid Superba (model KSRS25IHSS02) that will not stop making ice. The on/off switch does not work nor does the photo sensor recogize a full ice bin. Tried shutting off the water but the ice machines still cycles.
Is there a way to simply turn off the ice maker? Could this be a simple switch replacement? Or is the switch and photo sensor all connected the the PC board.
Thanks for any suggestions or help. Maybe its time for a new Frig.
Sounds like the relay on the sensor board ( AP3137510) is shorted and needs to be replaced. You can also manually turn off the ice maker by looking at the module on the left side. Look for a round, white spot inset into the black housing that looks like you could put a screwdriver in. Go ahead and put a screwdriver in the slot and turn it clockwise until it stops (about 1/4 turn). To turn the unit back on, turn it back.
Brian, thanks for the suggestion on how to manually turn off the ice maker. It worked great. Now I just need to order the sensor board and complete this repair.
Thanks for all your help !!!
--ted
