ScottR
#1 Posted : 17 years ago
ScottR
Oven had been working fine. Turned to bake and set temperature to 400.Returned to put food in and noticed oven had not started. It is a propane model. Turned controls to broil and still nothing. Turned to clean and oven came on and ignitor fired on bottom of oven .I checked wiring and all semed ok. Gas is on at regultor under oven. It has the delayed features on clock.When clean cycle came on the knob on the timer clock popped out. I tried to get oven to fire on bake with knobs in or out and still nothing. Stove top is electronic ignition also and it works fine. Any suggestions?
misterfixall
#2 Posted : 17 years ago
misterfixall
it may be selector switch
Viking gas broiler and oven not working (Oven Repair (including Ranges and Cooktops))
by Guest about a year ago
Dacor oven, upper oven not working (Oven Repair (including Ranges and Cooktops))
by notyepcars 2 years ago
oven not working, gives me a code F3 (Oven Repair (including Ranges and Cooktops))
by cj9113 3 years ago
GE PROFILE PGB995DET1WW Top oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 3 years ago
Whirlpool microwave/oven not working (Oven Repair (including Ranges and Cooktops))
by naik71 4 years ago
Thermador oven not working DP366CS/03 (Oven Repair (including Ranges and Cooktops))
by Chanmomu 5 years ago
whirlpool WOD93EC0AS double oven bottom oven not working (Oven Repair (including Ranges and Cooktops))
by Chemsal 5 years ago
KDRP467KSS08 / KDRP467KSS0 KitchenAid oven not working (Oven Repair (including Ranges and Cooktops))
by larrywick 5 years ago
Oven On light stays lit - Oven not working properly (Oven Repair (including Ranges and Cooktops))
by Lometir 6 years ago
ge oven not working (Oven Repair (including Ranges and Cooktops))
by mcp1212 6 years ago
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 7 years ago
Whirlpool Accubake Oven Not Working (Oven Repair (including Ranges and Cooktops))
by buddha61 7 years ago
Maytag oven not working (Oven Repair (including Ranges and Cooktops))
by dtmeyer 7 years ago
Oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by Nalk 8 years ago
stove oven not working but burnerws do (Oven Repair (including Ranges and Cooktops))
by jnevill1 8 years ago
