Oven had been working fine. Turned to bake and set temperature to 400.Returned to put food in and noticed oven had not started. It is a propane model. Turned controls to broil and still nothing. Turned to clean and oven came on and ignitor fired on bottom of oven .I checked wiring and all semed ok. Gas is on at regultor under oven. It has the delayed features on clock.When clean cycle came on the knob on the timer clock popped out. I tried to get oven to fire on bake with knobs in or out and still nothing. Stove top is electronic ignition also and it works fine. Any suggestions?
it may be selector switch
