Replacement parts for MAYTAG MDBH950AWS Dishwasher - Undercounter | AppliancePartsPros.comHere is the tech sheet
http://www.servicematters.com/maytag_library/docs/16023222.pdfHere is a manual
http://www.servicematters.com/maytag_library/docs/16021814.pdfI am assuming the unit is totally dead.
Sounds like you have a bad connection somewhere.
First remove power from the unit and check that the wire nuts connecting power to it are OK.
Next remove the doors inner panel and check that the wires from the control going under the unit are OK.
Check that the door switches are closing with a meter and that power is getting to the control board.
if OK.
Try the following cleaning procedure.
Check the control panel (keypad) with a meter. See the tech sheet.
If OK
Odds are the control board is shot.
Connector Cleaning / CheckingUnplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
