belladeablo
#1 Posted : Saturday, January 30, 2010 9:55:23 AM(UTC)
belladeablo
Have a Kenmore dryer, HE2, Model 101.87562601. Breaker on not tripped. Power button works. LED display lights. Door closes correctly. When I press the start button, it just beeps. When I open the door, press in the switch, press start, same beeps. Help please. What is my problem. Thanks.
#2 Posted : Saturday, January 30, 2010 2:38:08 PM(UTC)
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208572745.pdf
Try running the diagnostics to see if anything comes up
If nothing or all OK
Try doing the motor test 2 on page 5.
kayakcrzy
#3 Posted : Sunday, January 31, 2010 5:56:27 AM(UTC)
kayakcrzy
It is most likely the thermal fuse. The part # is 3392519 If you get a putty knife and slide it just above the bottom panel, about 4 inches from the right side, you will hit a clip that will release the bottom front panel on that side. Do the same on the other side. Remove the bottom front panel out of the way, and get on your stomach, and look in on the right side hard left, sitting on the vent tube are 2 parts. One of them is thin, and white, that is the thermal fuse. Unplug the dryer, and then take the 2 wires off of the thermal fuse, and put them together, and then put some tape around them to keep them together, and so the metal ends don't hit metal, and then plug in the dryer and see if it works. If so, DO NOT RUN the dryer with the fuse jumped out. It is the only thing pervented the dryer from burning down the house. Let me know how it goes. Tom www,applianceeducator.com
