Underdog
#1 Posted : Saturday, January 30, 2010 4:43:58 AM(UTC)
Underdog
I have a Maytag dryer that was working and stopped during a cycle. I pulled off the front cover and found that lint and hair had almost completely stopped air flow. I cleaned the lint and hair away from the dryer and all parts. Checked continuity on the high temp shut off- it read almost 0 omhs. Checked the thermostat at the blower and it reads 0 omhs at the two main leads, but also has two smaller leads on the top and bottom...when I check those the it shows very little on the meter.
Am I checking the thermostat properly?
BTW...motor moves freely and the high temp cutoff reads 0 omhs.
Should I just replace the thermostat?
#2 Posted : Saturday, January 30, 2010 6:10:58 AM(UTC)
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG PYE2300AYW Dryer - Ele | AppliancePartsPros.com
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Then check the door switch. Mechanically first to make sure it is being closed.
Then with a meter to be sure it's contacts are closing.
Next would be the thermal fuse Item 5 in Section 5
Unplug the unit and check it with a meter, should be 0 ohms.
Be sure to unplug one side of it when checking it.
If it is blown you have to find out what caused it to go.
It could be just the clog you had.
You will see it comes with a hi-limit thermostat as this thermostat should have regulated the temperature so that the fuse did not blow. It did not so it is assumed that it is bad.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
[COLOR="Blue"]I cleaned the lint and hair away from the dryer and all parts. Checked continuity on the high temp shut off- it read almost 0 omhs. Checked the thermostat at the blower and it reads 0 omhs at the two main leads, but also has two smaller leads on the top and bottom...when I check those the it shows very little on the meter.[/COLOR]
Just so we do not get confused use please use the terminology on the wiring diagram: thermal fuse; Safety thermostat (actually the hi-limit) and thermostat (actually the cycling thermostat)
The thermostat has 4 connections 2 of them are the contacts they should read 0 ohms, the other two are the internal heater they should read approximately 29,000 ohms.
[COLOR="Blue"]
Am I checking the thermostat properly?[/COLOR]
See below
[COLOR="Blue"]
Should I just replace the thermostat?[/COLOR]
No, it seems OK you may want to recheck it, see below.
kayakcrzy
#3 Posted : Sunday, January 31, 2010 6:24:12 AM(UTC)
kayakcrzy
The part you need is a thermal fuse kit. The part # is LA1053. If you pop the top of the dryer, and make sure you have it unplugged. You will see the heater in the back on the top, lookto the right of the heater housing, and follow the 2 white wires, and you will see the thermal fuse connected to the 2 white wires. It will be the size of a dime, and round. The best wat to replace it is just take the thermostat bracket off of the element housing. Take the lonf 1/4 inch screw that holds the element in place out, and pull the element, and then get a screw driver and pop out thermal fuse housing.
Once that is all done and you have the new one. Let's repair the reason why it went. While you still have the top up, we need to take the front off. There will be a screw on the inside of the front left side, about 6 inches down, it will be a 1/4 head size screw. Remove it, and the one on the other side. Then lean the front towards you, and remove the door switch wires. Remember where they go, and remove the front. Look down on the front on the bottom, where the blower housing is, and pull out all the lint. Reach inside the vent housing and clean it out good. It is a great dryer, but the vent system stinks. Put it back together, and you have it!! Let me know how it goes. Tom www.applianceeducator.com/parts,htm
Underdog
#4 Posted : Monday, February 1, 2010 10:53:50 AM(UTC)
Underdog
Thanks Kayak... it is in fact the thermal fuse. Ditto...the exhaust system bites. How often should I take the dryer apart to clean it.
Thanks for all the help guys!
kayakcrzy
#5 Posted : Monday, February 1, 2010 10:57:36 AM(UTC)
kayakcrzy
once every 6 months. Tom ApplianceEducator.com
