The dryer won't work when you push the button to start. We checked the door switch, its fine, and the timer is not broken and the fuses on the circuit to the house are fine. Its a 220V outlet. What else could it be?
First check the pigtail (cord) at the dryer. They sometimes burn up at the terminal block. After that check your t-stats by jumping them out. Don't miss the small one on the side of the heater. If the small t-stat on the side is bad you must also replace the larger one on top of the heater. They come as a kit.
