pwrply2
#1 Posted : Wednesday, April 16, 2008 5:06:58 PM(UTC)
pwrply2
The dryer won't work when you push the button to start. We checked the door switch, its fine, and the timer is not broken and the fuses on the circuit to the house are fine. Its a 220V outlet. What else could it be?
fixtec90
#2 Posted : Thursday, April 17, 2008 5:09:54 AM(UTC)
fixtec90
First check the pigtail (cord) at the dryer. They sometimes burn up at the terminal block. After that check your t-stats by jumping them out. Don't miss the small one on the side of the heater. If the small t-stat on the side is bad you must also replace the larger one on top of the heater. They come as a kit.
dryer not running (Dryer Repair)
by SteveDB 2/9/2016 5:18:51 PM(UTC)
Dryer not running (Dryer Repair)
by CComperry 3/3/2014 2:00:38 PM(UTC)
Maytag Performa dryer not running (Dryer Repair)
by bluex 9/19/2013 12:11:15 PM(UTC)
Kenmore Elec Dryer not running on air dry/no heat on all cycles (Dryer Repair)
by jmm53 5/9/2013 11:32:08 AM(UTC)
by Michael Walsh 5/2/2012 4:59:32 PM(UTC)
by Steven R Henderson 12/30/2011 8:06:34 PM(UTC)
Dryer not running!!! (Dryer Repair)
by mjones375 4/11/2011 6:57:05 AM(UTC)
Electric clothes dryer not running! (Dryer Repair)
by jjblum2002 2/2/2010 10:24:03 AM(UTC)
Frigidaire Dryer Not Running (Dryer Repair)
by QuarlJ01 9/23/2009 5:04:41 AM(UTC)
dryer not running thru full cycle (Dryer Repair)
by 30tredog 9/28/2008 5:15:40 PM(UTC)
dryer not running suddenly (Dryer Repair)
by Ellie69 9/26/2008 10:33:28 AM(UTC)
