tmarch1311
#1 Posted : Wednesday, April 16, 2008 2:01:55 PM(UTC)
tmarch1311
As this tub leans on all phases it is most notiable on spin cycles and the machine thumps horribly! can anyone give me an idea what to do? Is it a balnce ring problem?
bambiblaster
#2 Posted : Wednesday, April 16, 2008 4:50:41 PM(UTC)
bambiblaster
Slide out and tip back there should be a long spring coming from rear of tub to bottom rear of frame.. Sometimes the hole rust thru.. you can drill o hole next to the bad one for a quick fix...
bambiblaster attached the following image(s):
