As this tub leans on all phases it is most notiable on spin cycles and the machine thumps horribly! can anyone give me an idea what to do? Is it a balnce ring problem?
Slide out and tip back there should be a long spring coming from rear of tub to bottom rear of frame.. Sometimes the hole rust thru.. you can drill o hole next to the bad one for a quick fix... bambiblaster attached the following image(s):
