Today my wife dropped a new jar of peanut butter on the top of the dryer near the controls. Since then the dryer will not turn off, except when the door is open. I can turn the controls and set it and it seems to all still work and heat up, if I hit the cancel button, the controls go off but it is still spinning till I open the door or unplug it.. I taken the control board out and everything visually looks fine and is all plugged in. The board was already replaced under warranty when the dryer was new..Im not opposed to replacing it again - was just wondering if anyone had any suggestions, also any suggestions as far as where to get the new part.. I did find the board assembly for $201 online. (more than I paid for the dryer- was on clearance at Lowes)
THIS FORUM IS DEAD!!!!!!! |
