sidfink43 thanks for your help I won't be able to get back to this for about a week.
Originally Posted by: highwaystar ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) This unit completes all cycles, It just wont run thru a spin cycle. I ran diagnostics and it came up with a E47 code, which is board thinks the door PTC circuit is open in spin. It says to refer to Test 7, Which is remove door lock assembly and measure the resistance of the PTC. What is the PTC? Correction:Shorted or open. Defective door lock assembly. Reads around 1500 ohms. Defective Control board. What do you think? Where do I measure the resistance o n the door lock assembly? :confused: My washer was doing the same thing ( E47). Replaced the Door Lock Assy. and it fix the problem. Thanks for your help and support APP.:) :D
on the ptc if you have power going to the wax motor,should it be getting hot,and how long does it take for it to fully open
an appliance tech told me that means Positive Temperature Control...
