We have a dryer approx. 20 years old that requires us to cycle thru twice to get clothes dry. motor seems fine so I am thinking it could be the heating element or thermostat,,,any ideas ? thanks
The most common cause is a dirty vent system
Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load.
Both the above will allow you to check the air flow and temp. Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems. |
THIS FORUM IS DEAD!!!!!!! |
