cinda
#1 Posted : Wednesday, January 27, 2010 5:19:44 PM(UTC)
cinda
We have a dryer approx. 20 years old that requires us to cycle thru twice to get clothes dry. motor seems fine so I am thinking it could be the heating element or thermostat,,,any ideas ? thanks
#2 Posted : Thursday, January 28, 2010 1:24:16 AM(UTC)
The most common cause is a dirty vent system
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
dryer not heating well in place but works find when pulled away from wall (Dryer Repair)
by rjohnc 8/29/2013 12:01:56 PM(UTC)
Whirlpool Dryer not heating well (Dryer Repair)
by rockettme 6/7/2012 9:22:08 AM(UTC)
Maytag Dryer not heating well (Dryer Repair)
by indiana324 5/14/2011 11:52:25 AM(UTC)
