woodzee61
#1 Posted : Sunday, April 13, 2008 10:00:47 AM(UTC)
woodzee61
My freezer will freeze up in about one week after defrosting the coils with a hair dryer.I have replaced the defrost heater and thermo. I then replaced the main cntrol board.i waited week and took the back panel off and it was full of frost again. Does all the frost melt when working properly.And what do I do next.How to tell if the door seal is bad
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
GE side by side turns on only when I disconnect J4 plug (Refrigerator & Freezer Repair)
by PandaTaco 1/11/2024 10:04:34 AM(UTC)
GE side by side water and ice not working (General Talk)
by Guest 10/8/2022 6:17:31 AM(UTC)
GE Side by side fridge; control panel blank; not cooling (Refrigerator & Freezer Repair)
by peteror 3/20/2022 10:14:32 PM(UTC)
GE side by side PSS26SGPA SS (Refrigerator & Freezer Repair)
by Guest 1/23/2022 3:19:31 AM(UTC)
GE side by side clicks once by compressor then once on board. (Refrigerator & Freezer Repair)
by Schaanman 1/23/2022 2:03:33 AM(UTC)
GE side by side model GSS25KSTASS ice maker auger continues to run (Refrigerator & Freezer Repair)
by RodneyS 5/30/2021 2:59:27 PM(UTC)
GE Side by Side Freezer 25 degrees warmer than set-point (Refrigerator & Freezer Repair)
by reese600 1/21/2021 11:39:19 AM(UTC)
GE side by side starts and stops (Refrigerator & Freezer Repair)
by SethL 12/19/2020 6:58:00 AM(UTC)
GE Side by Side - Water/Ice Dispense (Refrigerator & Freezer Repair)
by USS Pogy 11/5/2020 4:08:04 AM(UTC)
GE Side by side GSHS6LGBBHSS (Refrigerator & Freezer Repair)
by Ksutherland 5/16/2020 10:05:38 AM(UTC)
GE side by side refregator does not start (Refrigerator & Freezer Repair)
by patel_bhavesh100 9/12/2019 5:32:28 AM(UTC)
GE side by side, uneven cooling (Refrigerator & Freezer Repair)
by GLMace 2/28/2019 2:46:16 PM(UTC)
GE Side by Side Thermistor Locations (Refrigerator & Freezer Repair)
by AlkiRich 1/3/2019 9:31:00 PM(UTC)
GE side by side, sporadic water and ice dispensing (Refrigerator & Freezer Repair)
by Ramski00 11/25/2018 12:13:04 PM(UTC)
