My dishwasher pumps water continually...even with the door open. I had to turn off the water supply to make it stop. I replaced the float switch and that seemed to work great for about 2 weeks and now it is doing it again. I saw another similar post where the answer is to change the water selenoid. I don't see that on my parts list...could it be the relay #3369447? is that the same part? Thanks
Rank: Administration
What they were referring to is the inlet water valve which consists of a solenoid and plastic housing: Water valve for 665.17735791When you say "My dishwasher pumps water continually..." - do you mean the dishwasher is being filled with water continuously or the pump/motor assembly is always on? If it's the former, replace the valve. If it's the latter, check your door switches first.
When the door is open the water keeps running but I can not hear the motor running. I ordered the part you listed above...thank you so much.
