jodoustou@yahoo.com
#1 Posted : Thursday, April 10, 2008 8:28:08 PM(UTC)
jodoustou@yahoo.com
My dishwasher pumps water continually...even with the door open. I had to turn off the water supply to make it stop. I replaced the float switch and that seemed to work great for about 2 weeks and now it is doing it again. I saw another similar post where the answer is to change the water selenoid. I don't see that on my parts list...could it be the relay #3369447? is that the same part? Thanks
Admin / APP Team
#2 Posted : Friday, April 11, 2008 9:39:22 AM(UTC)
Admin / APP Team
Rank: Administration
What they were referring to is the inlet water valve which consists of a solenoid and plastic housing:
Water valve for 665.17735791
UserPostedImage
When you say "My dishwasher pumps water continually..." - do you mean the dishwasher is being filled with water continuously or the pump/motor assembly is always on? If it's the former, replace the valve. If it's the latter, check your door switches first.
jodoustou@yahoo.com
#3 Posted : Sunday, April 13, 2008 10:22:03 AM(UTC)
jodoustou@yahoo.com
When the door is open the water keeps running but I can not hear the motor running. I ordered the part you listed above...thank you so much.
