AppliancePartsPros.com
Appliance Repair Help
Washer Repair
GE Washer won't agitate properly and can't figure out which part to get.
hi there, my GE wsm2700wcwww Washer won't agitate properly and I can't figure out which part to get. It had started squeaking loudly. when i removed the the agitator cap and the bolt i could see some cracks on what appears to be a metal ring inside the plastic agitator part. the pictures are attached. the metal seems to be attached to the plastic so i'm wondering if i'm looking at a cracked drive hub which is what i need to replace or is this just an attached part of the whole agitator which now has to be replaced. If it is a separate part, how do i detach it? Thanks for any and all help. phin66 attached the following image(s):
Well, a couple of things First of all your GE machine is a Frigidaire. It seems GE wanted to sell combos with having to go to the trouble of actually making one, so they got them from Frigidaire. Your agitator is one piece, and I would start by replacing it and/or the drive hub if you think the machine is operating correctly Here is a service manual for your machine. http://frigidaireservicetips.com/pdfs/488_3.pdf
Washer Repair
