phin66
#1 Posted : Sunday, January 24, 2010 6:56:10 AM(UTC)
phin66
hi there, my GE wsm2700wcwww Washer won't agitate properly and I can't figure out which part to get. It had started squeaking loudly. when i removed the the agitator cap and the bolt i could see some cracks on what appears to be a metal ring inside the plastic agitator part. the pictures are attached. the metal seems to be attached to the plastic so i'm wondering if i'm looking at a cracked drive hub which is what i need to replace or is this just an attached part of the whole agitator which now has to be replaced. If it is a separate part, how do i detach it? Thanks for any and all help.
phin66 attached the following image(s):
sidfink43
#2 Posted : Monday, January 25, 2010 4:22:54 PM(UTC)
sidfink43
Well, a couple of things
First of all your GE machine is a Frigidaire. It seems GE wanted to sell combos with having to go to the trouble of actually making one, so they got them from Frigidaire.
Your agitator is one piece, and I would start by replacing it and/or the drive hub if you think the machine is operating correctly
Here is a service manual for your machine.
http://frigidaireservicetips.com/pdfs/488_3.pdf
