jkuszik
#1 Posted : Thursday, January 21, 2010 10:59:33 AM(UTC)
jkuszik
I ordered a heat element from your company and want to know when changeing the element, I start by removing the back of the dryer. I believe the element is attached inside the panel. Am I correct and saying so?
sidfink43
#2 Posted : Sunday, January 24, 2010 6:20:36 AM(UTC)
sidfink43
Yep, take off the back and disconnect the heater housing and take of the screws that hold it on.
Should be an easy job, good luck.
Maytag dryer element replacement (Dryer Repair)
by jadeck 9/19/2010 3:41:07 PM(UTC)
