I ordered a heat element from your company and want to know when changeing the element, I start by removing the back of the dryer. I believe the element is attached inside the panel. Am I correct and saying so?
Yep, take off the back and disconnect the heater housing and take of the screws that hold it on.
Should be an easy job, good luck.
