Came home to a flooded kitchen. After removing all visible debris, we ran the dishwasher. There is standing water that will not drain. We are attempting to clear it but we are running into problems. We have removed the rotating arm, and then the cap with 8 screws. We can see what appears to be a screen, and we assume the hose/drain is underneath, but we can't remove the next layer. There is a black rotating disc with a small nut that we can't seem to reach. Suggestions? http://img686.**********...us/img686/6602/009bz.jpg
THIS FORUM IS DEAD!!!!!!! |
Stina,
Were you able to remove the black rotating disk and screw? I've tried but it's stuck. Tried WD-40 to no avail.
Namnyef
