rodanthe
#1 Posted : Monday, January 18, 2010 6:37:24 AM(UTC)
rodanthe
After a loud sound from the side of the upper oven door, it appears that the right side hinge spring has either broken or become detached causing reduced tension on the closing of the door. I have identified a replacement spring but wanted to know how much trouble it is to repair this type of problem (i.e. - how do I disassemble to replace part?) Thanks
Bill
#2 Posted : Monday, January 18, 2010 5:01:51 PM(UTC)
Bill,
The oven has to be removed from the cabinet and then the side panel has to be removed as well.
- The door hinge spring Part number: AP3026440
rodanthe
#3 Posted : Tuesday, January 19, 2010 6:15:34 AM(UTC)
rodanthe
Thanks for the reply and information Gene. Is there a reference available to describe how to remove the assembly from the cabinet? thanks again.
Bill
#4 Posted : Tuesday, January 19, 2010 11:36:00 AM(UTC)
Bill,
Unfortunately this oven is very old and no manuals available.
