steinl88
#1 Posted : Thursday, January 14, 2010 5:29:53 PM(UTC)
steinl88
How do you check and adjust for the proper water level in dishwasher. Currently, water is pouring out of the overflow assy. on to the kitchen floor. All over flow parts are new, stand pipe and float.
Thank you,
Kenny
steinl88@yahoo.com
#2 Posted : Friday, January 15, 2010 1:08:03 AM(UTC)
There is no adjustment for fill level, the fill is regulated by time and they assume the water pressure/flow will be at a normal rate to give the correct fill level.
The overfill switch/float should not be activated in normal use.
It is usually just a safety device.
Pump and motor replacement parts for WHIRLPOOL KUDS230Y2 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%209741531.pdf
Check to ensure that the unit is not leaving water in the tub after a drain cycle. You may have a partial drain plug. The most common place for this is where the drain hose enters the house plumbing.
Check that the fill valve is not leaking re: it is empty after a wash cycle and then overnight water leaks into the tub.
Check that the drain tube is looped minimum of 10 inches higher than where it enters the house plumbing. Could be it is siphoning water back into the unit or there is a partial house drain plug or it is overflowing back into the unit.
If the unit is attached to an air gap, check/clean it.
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder 11/22/2023 7:02:56 AM(UTC)
Kitchenaid dishwasher pump? (Dishwasher Repair)
by Guest 6/11/2023 10:15:41 AM(UTC)
KUDS02FRSS2 Kitchenaid dishwasher (Dishwasher Repair)
by RepairDude61 7/2/2022 3:45:51 PM(UTC)
KitchenAid Dishwasher Not drying (Dishwasher Repair)
by louie@DFW 4/8/2022 5:15:51 PM(UTC)
Kitchenaid Dishwasher Multiple Errors (Dishwasher Repair)
by flamingvan@yahoo.com 12/6/2021 3:49:43 AM(UTC)
Kitchenaid Dishwasher F9E4 (Dishwasher Repair)
by louisd 10/17/2021 4:22:16 PM(UTC)
Kitchenaid Dishwasher diverter motor replacement (Dishwasher Repair)
by kitchdish 5/28/2021 12:32:35 PM(UTC)
KitchenAid Dishwasher Issue (Dishwasher Repair)
by facecard 3/19/2021 6:20:02 AM(UTC)
KitchenAid Dishwasher KUDS30IXBL Thermal Fuse (Dishwasher Repair)
by Ed Explains It 3/16/2021 10:34:44 AM(UTC)
KitchenAid Dishwasher will not complete cleaning Cycle (Dishwasher Repair)
by KyKatt 12/16/2020 12:23:50 PM(UTC)
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
KitchenAid dishwasher filling up when turned off (Dishwasher Repair)
by RinOakland 9/14/2020 8:50:00 AM(UTC)
KitchenAid Dishwasher pops open(latch changed) (Dishwasher Repair)
by saads 8/8/2020 9:51:27 PM(UTC)
Kitchenaid Dishwasher Not Starting (Dishwasher Repair)
by willmt10 6/28/2020 4:22:06 PM(UTC)
(Help) KitchenAid Dishwasher wont fully drain on normal cycle (Dishwasher Repair)
by ToNeG24 5/28/2020 9:16:06 PM(UTC)
