AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
2nd post - Whirlpool dishwasher door kicking breaker
It's not the switches. Only the switch connected to the white wires is kicking the breaker. Other side is fine. I swapped the switches and the problem stayed with the white wires. I traced all the white wires looking for a bad spot but found nothing. ???????
Thanks, Larry
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
If you know how to read wiring diagrams, check out this diagram for your model. Check the heater, the water fill valve and the pump/motor assembly.
Dishwasher Repair
