f5string
#1 Posted : 18 years ago
f5string
It's not the switches. Only the switch connected to the white wires is kicking the breaker. Other side is fine. I swapped the switches and the problem stayed with the white wires. I traced all the white wires looking for a bad spot but found nothing. ???????
Thanks, Larry
Admin / APP Team
#2 Posted : 18 years ago
Admin / APP Team
Rank: Administration
Groups:
If you know how to read wiring diagrams, check out this diagram for your model. Check the heater, the water fill valve and the pump/motor assembly.
