lambchop
#1 Posted : Tuesday, January 12, 2010 5:07:56 PM(UTC)
lambchop
I have a keypad issue with this Oven. When you push the Number 5 on the keypad a 2 appears in the display. All the other functions on the membrane switch work correctly. Is the problem in the membrane switch or could it be in the circuit board ?? :confused:
Dave
#2 Posted : Wednesday, January 13, 2010 4:49:05 AM(UTC)
Here are the parts
Replacement parts for WHIRLPOOL KEBS107BAL3 | AppliancePartsPros.com
Here is a manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6342e2edf7772b6e852573440054cfc6/$FILE/4317418%20Single%20Wall%20Oven.pdf
It could be either.
The keypad my be outputting a 2 instead of a 5 OR the control board may be interpreting the code from the keypad incorrectly.
When you press 2 do you get 2?
Looks like this is a bubble membrane keypad you may be able to see/feel some warping of it's surface near these keys.
Unfortunately they do not provide a pin-out diagram for the keypad so you cannot check it.
I would say the more likely of the two is the keypad but I hate guessing at something like this especially when it is over $350.00.
You could try the following though I feel it is a long shot.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
Perhaps someone else will jump in with info on how to check the keypad !!!
lambchop
#3 Posted : Thursday, January 14, 2010 5:58:47 AM(UTC)
lambchop
Does anyone know how to access failure codes for a KEBS107BAL3 eye level oven ? It is a 1997 vintage unit. The stop, stop start method for the newer models does not work on this unit. Or if someone might have an electronic copy of the tech manual for this oven, that might help.
Thanks,
Dave
#4 Posted : Thursday, January 14, 2010 7:18:16 AM(UTC)
Rattling Fan Noise from Kitchen Aid Oven (Oven Repair (including Ranges and Cooktops))
by agdodge4x4 8/22/2017 10:39:22 AM(UTC)
Kitchen Aid oven problem (Oven Repair (including Ranges and Cooktops))
by Rawger11 9/2/2014 11:13:56 AM(UTC)
Kitchen Aid oven clicks and clicks and then loses temperature (Oven Repair (including Ranges and Cooktops))
by sandyben 12/1/2013 9:41:14 AM(UTC)
Kitchen Aid Oven not heating (Oven Repair (including Ranges and Cooktops))
by can_climber 11/20/2013 5:19:46 PM(UTC)
Kitchen aid oven lighting problems (Oven Repair (including Ranges and Cooktops))
by Kjp1969 9/9/2013 7:56:05 PM(UTC)
loud fan and dim display on Kitchen aid Oven (Oven Repair (including Ranges and Cooktops))
by hartsellemom 3/18/2013 9:57:31 AM(UTC)
Kitchen Aid Oven Bulb (Oven Repair (including Ranges and Cooktops))
by kriemer 11/14/2012 11:32:14 AM(UTC)
kitchen aid oven (Oven Repair (including Ranges and Cooktops))
by guychapman 10/25/2012 6:16:00 AM(UTC)
Kitchen Aid oven & stove top not working (Oven Repair (including Ranges and Cooktops))
by LBowman 7/1/2012 6:45:19 PM(UTC)
Kitchen Aid Oven door stuck locked (Oven Repair (including Ranges and Cooktops))
by bert156 6/14/2012 8:54:11 AM(UTC)
Control Clicking on late 1980's Kitchen Aid Oven (Oven Repair (including Ranges and Cooktops))
by Wayne Klinga 6/1/2012 11:51:50 AM(UTC)
Kitchen Aid oven handle falling off (Oven Repair (including Ranges and Cooktops))
by Boss0144 1/26/2012 4:48:44 PM(UTC)
Kitchen Aid Oven won't hold heat (Oven Repair (including Ranges and Cooktops))
by richardalan93 11/28/2011 4:24:29 PM(UTC)
Kitchen Aid oven need help accessing control panel (Oven Repair (including Ranges and Cooktops))
by mark763 10/29/2011 8:37:24 AM(UTC)
Kitchen Aid oven door removal - going crazy (Oven Repair (including Ranges and Cooktops))
by sun4jessi 10/19/2011 3:08:54 PM(UTC)
