LBowman
#1 Posted : Sunday, July 1, 2012 6:45:19 PM(UTC)
LBowman
Bought some used appliances. Not well maintained- filthy dirty. Previous owner said the igniter didn't work. He wasn't specific- all conversation by e-mail since he had moved away and left selling the things up to his dad. Worked and worked to get them cleaned up and looking nice. Finally got into our house, installed them and found the burners on top won't ignite. I can light them with a lighter but the igniter doesn't spark. I don't see anything listed for a spark igniter for the burners. Also, the oven takes forever to preheat. The broiler coil gets hot but I don't hear a burner in the oven try to ignite. Any suggestions? Also, I have to change the water solenoid valve for the ice maker in my K-A KSRG25FKSS16 refrigerator. How do the water lines disconnect from the valve?
Thank you so much for your assistance,
Larry:confused:
#2 Posted : Monday, July 2, 2012 1:46:19 PM(UTC)
Hi Larry,
Most likely the problem with your range is a bad spark module which is located inside the control panel.
- The spark module Part number: W10331686
Here are the breakdown diagrams and Replacement parts for Whirlpool KGSA906PSS00 30" Slide-In GAS OVEN CONVECTION | AppliancePartsPros.com
I believe the water valve comes with the installation instructions.
- The water valve Part number: W10408179
