Stonehenge
#1 Posted : 15 years ago
Stonehenge
Is it difficult to fix the squeek on my dryer. Is it possibly a bearing needing to be replaced?
#2 Posted : 15 years ago
Replacement parts for MAYTAG MDE6000AYW Dryer - Ele | AppliancePartsPros.com
[COLOR="Blue"]Is it difficult to fix the squeek on my dryer.[/COLOR]
Cannot say depends on what you feel is difficult.
It will be several hours of work.
Finding the cause is often harder that fixing it.
[COLOR="Blue"]
Is it possibly a bearing needing to be replaced?[/COLOR]
Try to get the general location of where the squeak originates before opening it up..
It can be a number of things: front glides, rear support rollers, idler wheel, motor bearings.
You will have to open it up and check these for slop/wear.
Might as well also check the belt etc., do an overhaul while you have it opened up.
Give the interior a good cleaning, including the blower wheel.
Also a good time to check/clean you vent system
Here is a manual for this series of dryer which should be useful.
http://www.servicematters.com/maytag_library/docs/16023110.pdf
And here is a good site for basic dryer repair help
http://www.applianceaid.com/dryers.html
Squeeky dryer (Dryer Repair)
by lexusnip 13 years ago
by julieshaver@bellsouth.net 13 years ago
ear piercing squeeky dryer!!! Help! (Dryer Repair)
by fawn_eyes888 15 years ago
Squeeky Dryer (Dryer Repair)
by tbela 15 years ago
squeeky dryer (Dryer Repair)
by shorembo 15 years ago
by jooey2 15 years ago
by Squeeky Dryer 16 years ago
by clayandlin 16 years ago
