Is it difficult to fix the squeek on my dryer. Is it possibly a bearing needing to be replaced?
Here are your parts Replacement parts for MAYTAG MDE6000AYW Dryer - Ele | AppliancePartsPros.com[COLOR="Blue"]Is it difficult to fix the squeek on my dryer.[/COLOR] Cannot say depends on what you feel is difficult. It will be several hours of work. Finding the cause is often harder that fixing it. [COLOR="Blue"] Is it possibly a bearing needing to be replaced?[/COLOR] Try to get the general location of where the squeak originates before opening it up.. It can be a number of things: front glides, rear support rollers, idler wheel, motor bearings. You will have to open it up and check these for slop/wear. Might as well also check the belt etc., do an overhaul while you have it opened up. Give the interior a good cleaning, including the blower wheel. Also a good time to check/clean you vent system Here is a manual for this series of dryer which should be useful. http://www.servicematters.com/maytag_library/docs/16023110.pdfAnd here is a good site for basic dryer repair help http://www.applianceaid.com/dryers.html |
THIS FORUM IS DEAD!!!!!!! |
