Replacement parts for JENN-AIR JGS8750BDS Range - S/c S/i Gas | AppliancePartsPros.comHere is the tech sheet with keypad pinout info
http://www.servicematters.com/maytag_library/docs/16026924.pdfAnd finally a manual
http://www.servicematters.com/maytag_library/docs/16026923.pdfthe 1,2,3,4,5,6 dont work [COLOR="Blue"]Uses Pin 2 as common[/COLOR]
but 7,8,9 work [COLOR="Blue"]Uses Pin 3 as common[/COLOR] and the rest of the touch screen works
Try the following cleaning procedure.
Also check the keypad with a meter. This type of problem is usually the keypad but can be the control board, only way to tell for sure is with a meter.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
