mrden
#1 Posted : Monday, January 11, 2010 5:39:27 PM(UTC)
mrden
the 1,2,3,4,5,6 dont work but 7,8,9 work and the rest of the touch screen works
#2 Posted : Tuesday, January 12, 2010 1:49:35 AM(UTC)
Replacement parts for JENN-AIR JGS8750BDS Range - S/c S/i Gas | AppliancePartsPros.com
Here is the tech sheet with keypad pinout info
http://www.servicematters.com/maytag_library/docs/16026924.pdf
And finally a manual
http://www.servicematters.com/maytag_library/docs/16026923.pdf
the 1,2,3,4,5,6 dont work [COLOR="Blue"]Uses Pin 2 as common[/COLOR]
but 7,8,9 work [COLOR="Blue"]Uses Pin 3 as common[/COLOR] and the rest of the touch screen works
Try the following cleaning procedure.
Also check the keypad with a meter. This type of problem is usually the keypad but can be the control board, only way to tell for sure is with a meter.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
mrden
#3 Posted : Wednesday, January 13, 2010 10:45:27 AM(UTC)
mrden
how do i know which is the # 1 and the # 7 to short out which side do i count from?i Assume i touch the tips of the contacts with my meter and get continunity? thanks
#4 Posted : Wednesday, January 13, 2010 12:20:32 PM(UTC)
[COLOR="Blue"]how do i know which is the # 1 and the # 7 to short out which side do i count from?[/COLOR]
Take a look at the tech sheet it shows track #1 location.
Once you find one switch pin-out it will confirm your counting.
[COLOR="Blue"]
i Assume i touch the tips of the contacts with my meter and get continunity? [/COLOR]
Yes open normally and continuity when the key is pressed.
So do 7,8 and 9 first as you know they work.
Also note that pin 2 is common to all the keys that do not work so carefully inspect this track and this location on the boards connector.
