pinkcouch
#1 Posted : Sunday, January 10, 2010 6:24:42 PM(UTC)
pinkcouch
dryer will not dry clothes in one cycle, i have to run the dryer 3 times for one load to dry
#2 Posted : Monday, January 11, 2010 2:11:51 AM(UTC)
Try this to narrow down the cause
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
