dryer will not dry clothes in one cycle, i have to run the dryer 3 times for one load to dry
Try this to narrow down the cause Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load.
Both the above will allow you to check the air flow and temp. Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems. |
THIS FORUM IS DEAD!!!!!!! |
