Get up this morning, to melted ice cream,and other gunk in freezer side and warm everything in refrigerator side....Cleaned coil underneath,no help.All fans run, but dont know how to tell if compressor may be ki-boshed. All that should be cold isnt.Turning refrig. knob up top shuts off fans, but temp control seems to be inoperative. Any suggestions welcome. Im slightly inclined with appliances,although gas is my forte,I'd like to save $$$ on a service call or new unit Thanks RustyD 3dabbott@gmail.com
Here are your parts Replacement parts for WHIRLPOOL ED25RFXFN03 | AppliancePartsPros.comHere is the tech sheet http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%202186936.pdf[COLOR="Blue"]All fans run, but dont know how to tell if compressor may be ki-boshed. All that should be cold isnt.Turning refrig. knob up top shuts off fans, but temp control seems to be inoperative.[/COLOR] From the above I assume that you do not hear the compressor turn on. One way to tell if it is on is to pull the unit out and listen/feel it. If it is warm, humming and you can feel it is vibrating it is on. If not on you could unplug the unit, short the contacts on the thermostat together, plug it in and give it a try. If the compressor comes on your thermostat is toast. If it is on, then it is probably one or 3 things. 1. Low freon 2. A defrost problem either the timer, heater or defrost thermostat. 3. The compressor is toast. For the first 2 remove the evaporator so you can see the evaporator coils. If heavily iced/frosted over you have a defrost problem. If there is only frost is one area or it is very blotchy then you are probably low on freon. This or a bad compressor is often the end of the life for a fridge as both are expensive to repair and you need a pro to fix it. Also there is no use repairing a low freon condition unless the leak can be found and sealed. Here are a couple good sites with basic fridge repair help http://www.applianceaid.com/frig.htmlRefrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com |
THIS FORUM IS DEAD!!!!!!! |
