sully
#1 Posted : Thursday, March 27, 2008 5:41:33 PM(UTC)
sully
My dryer was running for three hours blowing cold air. I figured out that my thermo fuse broke- I replaced it. It heat up again but seems very hot. I put a load in for 30 min. But it keeps on going and seems too hot. The vent is clear, Could it be the thermal high limit thermostat control? help?
Thanks.
fixtec90
#2 Posted : Friday, March 28, 2008 5:39:39 AM(UTC)
fixtec90
Did you clean your vent when you changed the t-fuse especially the point where it exits the house? If you're positive it's clear one of the t-stats is bad. The cycling t-stat is the normal culprit, but I'm not sure if your gas dryer has that type of t-stat. If not I'd suspect the hi-limit, but would need a wiring diagram before I'd put any money on the diagnosis.
dryer is too hot! (Dryer Repair)
by lokahiboy 7/20/2011 4:39:50 PM(UTC)
Dryer is too hot on all settings (Dryer Repair)
by klray 6/24/2011 5:09:49 AM(UTC)
Dryer is too hot (Dryer Repair)
by gramparon 1/19/2011 4:16:24 PM(UTC)
Dryer is too Hot (Dryer Repair)
by wrkeels@comcast.net 7/19/2009 2:01:13 PM(UTC)
dryer is too hot (Dryer Repair)
by 12wireless 1/7/2008 6:55:10 AM(UTC)
