3 days ago the refrigerator and freezer just stopped cooling, ice and frozen items began melting. Can't really afford a new one at this time. Is there anything that can be done?
THIS FORUM IS DEAD!!!!!!! |
Thank you for the reply. Yesterday after it had been unplugged overnight I plugged it back in. The icemaker made ice. The refrigerator part seemed to get cool and was icing a little on the bottom. This morning however, the refrigerator part is warm and the ice maker has not made ice. It's dripping water. There's motor for something running but I don't know if it's the compressor (I would have thought it was).
You have to find out what is actually running. The unit has a compressor, a condenser/compressor fan and an evaporator fan all of which can be something is running. |
does it help to know that the freezer has frost but the fridge is not getting cold
If the compressor is not running and the freezer is not warm, could be the thermostat (Item 21 in Section 5) is shot. If this is a two wire thermostat, you could unplug the unit, short the wires to the thermostat together, tape them up so they cannot short to anything, plug it in and give it a try. If the unit fires up and gets cold then the thermostat is probably the cause.
Check that the damper is opening to let cold air into the fresh food area, Item 115 in Section 5.
If the compressor and the fans are off, you could be stuck in a defrost cycle. |
