MikeDiehl
#1 Posted : Thursday, March 27, 2008 12:48:55 PM(UTC)
MikeDiehl
My Maytag range cooktop has the four burner and a warming area configuration. The front left is the large burner the others are fairly small.
The front right burner looks to be about 3-4 inches smaller than the one on the front left. Is it possible to replace the front right burner with one the same size as the front left?
Avoid Siamesed Jenn-Air Cooktop Burners Upon Switch Replacement (Oven Repair (including Ranges and Cooktops))
by Tigertank84 2/26/2020 10:19:47 AM(UTC)
Both oven and cooktop burners work intermittently (Oven Repair (including Ranges and Cooktops))
by WmHBlair 9/12/2014 9:54:15 AM(UTC)
whirlpool cooktop burners heats slow minimum heat on all burners (Oven Repair (including Ranges and Cooktops))
by wigginscallie@yahoo,com 8/15/2013 7:09:45 PM(UTC)
Cooktop burners/parts -- Possibly Roper (Oven Repair (including Ranges and Cooktops))
by keyjo50 6/10/2011 3:12:53 PM(UTC)
Cooktop burners on when they shouldn't be (Oven Repair (including Ranges and Cooktops))
by 440@gmx.us 4/1/2011 5:09:08 PM(UTC)
Cooktop Burners low temp. too hot (Oven Repair (including Ranges and Cooktops))
by bobharrison5 1/7/2011 12:49:58 PM(UTC)
Electric Cooktop burners go on and off (Oven Repair (including Ranges and Cooktops))
by mjhaston 10/15/2010 4:51:26 AM(UTC)
Ceramic Cooktop Burners do not heat (Oven Repair (including Ranges and Cooktops))
by saterry 12/11/2009 7:17:46 PM(UTC)
Radiant cooktop burners turning on and off (Oven Repair (including Ranges and Cooktops))
Belarus mark0547 8/16/2009 12:50:29 PM(UTC)
sealed cooktop burners low flame large burners only (Oven Repair (including Ranges and Cooktops))
by heavy chevy 12/21/2007 4:28:19 PM(UTC)
