my ice maker timer goes through cycle but the water control value does not recieve 120vac .Replace wiring harnes because had no voltage to motor module.Motor module goes through cycle but no water to tray.Water from dispensor side of value works fine.
Disconnect the wiring connector from the ice maker side of the valve. Also disconnect the water line that goes to the ice maker from the valve. Leave the other lines connected. Remove the valve and place it into a bucket or other non-metallic container. Apply 120VAC to the terminals just long enough to see if water flows from the valve. If not, replace the valve.
