AppliancePartsPros.com
Appliance Repair Help
Washer Repair
maytag spin cycle does not get enough water out of clothes
The washer is squealing during the spin cycle and the clothes come out quite wet.
Hi Mitchel, The first thing I would do is raise up the washer from the front, remove the belt and check how the drain pump is moving in both directions. If it does not move freely then the drain pump has to be replaced. - The part number for the drain pump is AP3447809 Here are the break down diagrams for the Maytag washer Model PAV3240AWWGene.
Also, check with a small load of clothes, if it then spins all the water out, you have a slipping clutch due to a worn snubber. Post results
Washer Repair
