mitchel chad
#1 Posted : Tuesday, March 25, 2008 5:26:01 PM(UTC)
mitchel chad
The washer is squealing during the spin cycle and the clothes come out quite wet.
#2 Posted : Wednesday, March 26, 2008 2:00:29 PM(UTC)
Hi Mitchel,
The first thing I would do is raise up the washer from the front, remove the belt and check how the drain pump is moving in both directions.
If it does not move freely then the drain pump has to be replaced.
- The part number for the drain pump is AP3447809
Here are the break down diagrams for the Maytag washer Model PAV3240AWW
#3 Posted : Wednesday, March 26, 2008 2:08:04 PM(UTC)
Also, check with a small load of clothes, if it then spins all the water out, you have a slipping clutch due to a worn snubber. Post results
