denny o
#1 Posted : Tuesday, March 25, 2008 3:13:31 PM(UTC)
denny o
When washer starts spin cycle, it makes a banging noise. Open the lid and you can move the tub back and forth too easy. Is this worth fixing? Washer is probably closer to 10 years old.
bambiblaster
#2 Posted : Tuesday, March 25, 2008 4:59:09 PM(UTC)
bambiblaster
Its a direct drive washer resting on a pedistal with 4 springs keeping it centered.. it will move easily around in cabinet.. check that the load is even and also that the springs ar attached and level the machine
denny o
#3 Posted : Wednesday, March 26, 2008 3:43:51 AM(UTC)
denny o
The washer made this noise even when empty. How can I check to see if the springs are still attached? Also, when it stops from the spin cycle, it sometimes clunks and the basket moves quite a bit.
