I just purchase a new safety valve and installed it. The oven still does not lite.The oven igniter glows a brite white and there is 120vac at the valve.The gas is on at the wall and for the oven which has a separate shut off built in. Bad Valve? I just purchased it from AppliancePartsPros.
Kale Bridge
