kb1553
#1 Posted : Monday, March 24, 2008 10:36:23 AM(UTC)
kb1553
I just purchase a new safety valve and installed it. The oven still does not lite.The oven igniter glows a brite white and there is 120vac at the valve.The gas is on at the wall and for the oven which has a separate shut off built in.
Bad Valve? I just purchased it from AppliancePartsPros.
Kale Bridge
#2 Posted : Monday, March 24, 2008 6:37:48 PM(UTC)
Hi Kale,
Most likely the problem is a bad igniter and not the gas valve.
You can learn how the oven igniter works from one of previous posts: http://forum.appliancepartspros...1897-oven-wont-lite.html
- The part number for the oven igniter is AP205873
Here are the break down diagrams for the Magic Chef range Model 31FA-3KX
Guest (4)
