cartier
#1 Posted : Monday, March 24, 2008 4:08:31 AM(UTC)
cartier
GE Profile washer starts to fill and runs a minute or less then shuts off. I have noticed that I can tap the control panel on the right front(not on the switches but on the frame of the control panel and it will immediately cut off.
Would appreciate a reply and suggestion of how to repair it. If i have to take the control panel cover off, how do I do that?
Thanks,
Frank
#2 Posted : Monday, March 24, 2008 3:23:55 PM(UTC)
Hi Frank,
You have to open the control panel (remove a few screws on top of the control panel) and check all wires to the control board.
If there is nothing wrong then the control board has to be replaced.
- The part number for the control assembly is AP3156198
Here are the break down diagrams for the GE washer Model WSSE4220A0WW
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
GE profile washer won't start (Washer Repair)
by Blecun 2/10/2020 7:05:41 AM(UTC)
Control panel for GE Profile washer (Washer Repair)
by AmyC_1012 7/25/2018 7:50:00 AM(UTC)
GE Profile washer clogged air dome (Washer Repair)
by pgr8house 8/6/2017 2:26:23 PM(UTC)
GE Profile washer not spinning (Washer Repair)
by LSUStephen 7/16/2017 1:25:43 PM(UTC)
GE Profile Washer Dripping When Not in Use (Washer Repair)
by Sara6181 6/11/2017 10:17:06 AM(UTC)
GE Profile washer won't fill all the way (Washer Repair)
by jimlansing 1/16/2016 4:29:14 PM(UTC)
GE Profile washer - washes, drains, no spin (Washer Repair)
by cgiuffre 1/6/2016 6:06:10 PM(UTC)
GE Profile Washer won't spin only on delicate setting (Washer Repair)
by balmoral201 3/28/2015 12:28:37 PM(UTC)
GE Profile Washer Stops during filling & wont rinse (Washer Repair)
by KLS2015 3/22/2015 7:26:19 PM(UTC)
GE Profile Washer water level knob is stuck (Washer Repair)
by jj605v 12/29/2014 2:03:41 PM(UTC)
Ge Profile Washer Over Fills (Washer Repair)
by APPLIANCEDUDE1972 12/28/2014 5:56:26 PM(UTC)
ge profile washer (Washer Repair)
by Mike Elliot 12/7/2014 7:33:29 AM(UTC)
GE profile washer repeats the rinse cycle (Washer Repair)
by darylp 12/2/2014 3:53:03 PM(UTC)
ge profile washer will not spin (Washer Repair)
by ron dog 11/29/2014 5:27:31 PM(UTC)
