My Kitchen Aid Washer vibrates excessively during the spin cylce to the extent it even moves a couple inches from its original location. The washer is level. I have inspected all the springs. They appear to be in good condition. The suspension pads and tub pads are all in place and appear good. Nothing appears broken or loose on the base.
It never used to vibrate this bad. Any suggestions? Please help.
It is almost impossible to detect a problem with the springs by visible examination. I would start by replacing them, if that does not solve the problem replacing the plate may fix it. Part number: AP3131363
