You have been a member since:: 2/13/2011(UTC) Posts: 1
when this machine is in a spin cycle the tube vibrates an excessive amouint. i have replaced the snubber and the problem is still there.
Did you clean the area where the snubber rides, and apply some corn starch powder there. Also check the base of the machine for cracks. This can cause vibration as well. Check and make sure the springs are not stretched to much causing the tub to run "loose". If the springs are bad then you will need this part. Part number: AP4009656
