roy guinn
#1 Posted : Tuesday, February 15, 2011 9:55:00 AM(UTC)
roy guinn
when this machine is in a spin cycle the tube vibrates an excessive amouint. i have replaced the snubber and the problem is still there.
Jeff / APP Team
#2 Posted : Wednesday, February 16, 2011 6:59:27 AM(UTC)
Jeff / APP Team
Did you clean the area where the snubber rides, and apply some corn starch powder there. Also check the base of the machine for cracks. This can cause vibration as well. Check and make sure the springs are not stretched to much causing the tub to run "loose". If the springs are bad then you will need this part.
Part number: AP4009656
If the base is bad you will need this part
Part number: AP4024669
