I have an Amana LEA60AW electric dryer that won't start. Have never had any problems with it have had it over 10 yrs. Was working fine then all the sudden went to push the button in to start it and it won't turn on. I'm novice at working on dryers so I'm hoping to get some advice on what I should look at, I think the timer should be replaced but want to ask for opinions before I but it. Thanks in Advance!
is there any noise when you push the start button? if no then check for voltage at the outlet to make sure it is getting power
