Francis Rodrigue
#1 Posted : Thursday, March 20, 2008 4:31:01 PM(UTC)
Francis Rodrigue
The problem I am having is that once the oven reaches the desired temp. it will not turn back on. But if I set the temp at 425 and higher it will maintain the temp. The broiler always?
#2 Posted : Friday, March 21, 2008 3:24:56 PM(UTC)
Hi Francis,
What was shown on the display when the oven did not turn back on?
Was it blank?
What did you mean:"The broiler always?"?
Francis Rodrigue
#3 Posted : Friday, March 21, 2008 4:11:29 PM(UTC)
Francis Rodrigue
Hi Gene, yes the display remains blank and I meant that when you use the broiler it always works and stays on.
Thank you
#4 Posted : Friday, March 21, 2008 4:58:13 PM(UTC)
Francis,
Most likely the problem is a bad control board which has to be replaced.
- The part number for the control board is AP3792697
If you can not use the old overlay, the part number for the overlay is AP2025084
